Engine won't accelerate when first started
Propane gm engine starts and runs poorly and won't accelerate for a bit, then runs fine. If I disconnect wiring to governor solenoid it revs immediately when pushing accelerator pedal. Changed gov solenoid already. When it sits a while this occurs again Any ideas??
  • Posted 18 Sep 2016 08:45
  • By billybonca
  • joined 18 Sep'16 - 1 message
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
