Engine shuts down after starting
Early edition FG25ST-14.
Start up the engine, after about 30 seconds, the MIL lights up.
45 to 60 seconds after the MIL turns on, the engine stops running.
Turn off the key and let it sit for a minute and it will crank up and repeat that.
It is showing code P1241 in the history and it shows P1241 in the active DTC line when looking at the data display on the service tool.
But it has been a challenge to get the reader to boot up and then get it over to the data display before the engine dies and causes a communication failure.
P1241 is "LPG F/inj failure (no inj medium zone).
Anybody ran into something like this on a -14 Komatsu?
  • Posted 11 Apr 2014 15:03
  • By L1ftmech
  • Tennessee, United States
swoop, for me;
"people tend to look at you funny and start walking in the other direction to avoid you",,,
always...
lol
  • Posted 20 Apr 2014 05:48
Final report from L1ftmech to L1ftmech on this issue.
New main injector arrived yesterday and engine is now running well.
On to other repairs!
  • Posted 20 Apr 2014 01:41
  • By L1ftmech
hehe... i talk to myself all the time too... i tend to call it rehearsing what i'm going to say to whomever i'm thinking about at the time.
whats interesting though is when you start arguing with yourself during the discussion... people tend to look at you funny and start walking in the other direction to avoid you... lol
  • Posted 16 Apr 2014 21:06
Actually Ed, I did that in fun, I wasn't certain that the thread was even being posted where others could see it without digging into the Komatsu section.
And I did want to share it.
The thing about the Discover card commercial was just because it was fresh on my mind.
The other day at work another mechanic made a remark that we have a mechanic on our staff that would have been a natural for the commercial because he already talks to himself all the time.
  • Posted 16 Apr 2014 14:07
  • By L1ftmech
I see that you do know that on Internet forums, the only way to get "intelligent conversation" is to reply to your own self...
lol...
But hey, thanx for returning and letting us know what really fixed the problem.
  • Posted 16 Apr 2014 06:53
No problem L1ftmech, you're welcome.
  • Posted 16 Apr 2014 01:54
  • By L1ftmech
Thanks L1ftmech.
  • Posted 16 Apr 2014 01:53
  • By L1ftmech
Well, this thread has turned out like the Discover card commercials where "we treat you like you would treat you".
Cause of problem identified.
Main injector coil apparently becomes open for just a millisecond or so sometime after the engine starts, causing the ECM to think that injection has stopped and therefore cut power to the interceptor valve. I suspected something like this but I wanted to confirm before arbitrarily swapping parts from the one other Komatsu truck we have here that can serve as a donor, and especially before ordering any new parts.
So I made an extension lead of AWG 18 wire that I inserted into relay terminal #30 (feed out to interceptor valve) of relay # 6 in the EPA relay box on the truck. This extension lead allowed me to "tap into the circuit" and observe the voltage on the circuit, seeing the voltage disappear at the same time the MIL lit up. That was the moment the ECM received the signal that injection had stopped (setting code P1241) and in turn the ECM cuts power to the interceptor valve.
Now I just had to figure out what was causing the ECM to think injection had halted.
To that end I swapped the injector driver module from our other Komatsu -14 over to the ailing truck and the problem persisted.
Next, I decided to swap the main injector. Bingo! With the injector from the other truck, the engine would run just fine and never turned on the MIL.
But just to make the test a double blind thing, I put the injector from the ailing truck in the donor truck and as soon as I started the engine and touched the accelerator, the MIL lit up.
Connecting the reader to the truck showed it also had registered code P1241.
I erased the code and put the donor truck back together with its original parts and put it back to work.
Have an injector coming.
  • Posted 16 Apr 2014 01:24
  • Modified 16 Apr 2014 01:52 by poster
  • By L1ftmech
Thanks in advance to the administrator for fixing this double post also (actually, it showed up as a double thread). I wondered if this thread was even showing up in the daily discussions as I have not seen it there myself and it has not gotten any responses so far.
  • Posted 14 Apr 2014 14:43
  • Modified 14 Apr 2014 15:00 by poster
  • By L1ftmech
Tapio Rummukainen Tapio Rummukainen
President, Logisnext Europe
Chief operating officer, Clark Material Handling Company
Lithium battery sales manager, BSL Battery
Chief executive officer, Corvus Robotics
Taylor TXB180S
Toyota 3FD100
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
