Engine shut down in 30 seconds
Model not listed in here so it's a glp080vxnase090. F813v02425e. Unit shows to be in start cycle. Starter won't crank. F7 fuse has no power. Replaced relay for start and tested circuits. Relay clicks on but no input power to relay thus no power to f7. Shows a error code for rear taillights. No other errors are present. Customer had 2 wires to start unit direct to starter and would start and run fine. Inspected pdm and no visible damage or signs of fault.
  • Posted 27 Jan 2018 01:32
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
this might sound rediculous but repair the tail light circuit fault
on the newer model trucks if the tail lights dont work it is now considered a safety feature and will shut the truck down from what i understand
  • Posted 29 Jan 2018 09:46
  • Modified 29 Jan 2018 09:49 by poster
  • joined 23 Mar'12 - 3,693 messages
Are you seeing a specific fault code?
  • Posted 29 Jan 2018 01:00
  • By BREWSKI
If you have lost power to the F7 fuse your problem is in the PDM. The fuses are fed from the primary positive rail inside the PDM.
  • Posted 29 Jan 2018 00:59
  • By BREWSKI
Sue Tomic Sue Tomic
SMV (Konecranes) 4531CC5
Hangcha FLDCXT160
Sue Tomic Sue Tomic
