Engine removal
This truck has a Perkins diesel engine. We have unbolted the engine from the flywheel housing, removed all the bolts holding the torque converter and the motor mount bolts. The engine will pivot around the flywheel housing and we can pry it out about 3/4 inch, but no further.
Any idea what we are missing here?
ramon_m
  • Posted 16 Oct 2014 01:43
  • By ramon_m
  • joined 30 May'14 - 42 messages
Perseverence is a virtue.
check and make sure the bellhousing has enough clearance for the flywheel to clear
i've seen in some cases where the bellhousing has to come with the engine, flywheel included and once you get the assembly out then pull the flywheel out through the transmission end of the bellhousing and then remove the bellhousing.
i know it seems bass ackwards but the mfg did not make clearances enough to allow the flywheel past that side of the bellhousing so you have to pull it all and remove it after you get the engine out.
  • Posted 16 Oct 2014 20:42
  • Modified 16 Oct 2014 20:44 by poster
Sue Tomic Sue Tomic
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Mitsubishi FGE35AT
USD1
Mitsubishi FGE35AT
