E50Z-33 error code 8
This fork has broken down once again. I was getting a code 7. I noticed that the pedal was loose and when I went to investigate, i noticed that the hinge screw was almost completely out. It appears that there should be a lock nut , washer or some sort of threadlocker on this component so it doesn't unscrew overtime.. Any way, I got the assembly back on track. Anyhow, Now I am getting and error code 8. When I run the diagnostic mode, all of the switches seam to be working. and the POT reads 9volts when the petal is up and 1.2 volts when the petal is fully depressed. The directional switches read correctly and the accelerator start switch reads correctly with a pot voltage of 4 when it is switched. I would be most appreciative if one of you would point me in the right direction.
  • Posted 10 Feb 2017 02:19
  • By metalshopdave
  • joined 10 Feb'17 - 1 message
Minimum accelerator wiper voltage should be 10.70 volts with the pedal fully up. Error code is for acclerator wiper voltage is too low. Adjust the acclerator senosr while watching the voltage on the dash disply.
  • Posted 10 Feb 2017 13:58
  • By glock01
  • joined 26 Apr'09 - 19 messages
  • Idaho, United States
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
