DTC L189
This unit will drive fine but some times when operating any of the hydraulic functions Code L189 comes up with a Lightening bolt then looses Hydraulic function.
Rekey Hydraulic functions is fine ,But some times code will just come up when hydraulic function is demanded.
Jump on truck in five minutes later works fine ?
Customer also says problem will not occur when forks are above 36" of ground
Mast has no sensors on it
  • Posted 11 Jul 2024 04:23
  • By pacfork
  • joined 2 Jun'07 - 55 messages
  • British Columbia, Canada
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
