Drive tire studs broke off
RC 5500 drive wheel studs broke off.
How do you remove the spindle off the drive unit in order to replace the studs?
It's a spline shaft fit. How to remove it? Is there a special tool required?
There are five notched areas. I have a three jawed puller that will not evenly fit in the five notched area. Do they make a puller that has five jaws to fit in these notches? Thanks
  • Posted 31 Jul 2022 07:07
  • By BigAl88246
  • joined 5 Apr'17 - 13 messages
Crown does make a special tool to fix this however it is possible to do it without.
  • Posted 17 Jun 2023 07:53
  • By Landry_Houston
  • joined 1 Nov'22 - 5 messages
  • Nevada, United States
Landry Houston
Probably easier just to change out the whole sub-assembly. As mentioned by some other techs here, they are a bear to remove even with the tool. Sub-assembly can be replaced in about an hour. Taking the sub assembly apart will eat up quite a few man hours!
  • Posted 27 Apr 2023 13:07
  • By Jearol_Sorrels
  • joined 1 Dec'22 - 3 messages
They are the same as the SC5200, There is a special puller you can buy from Crown but I just made my own, they are as tight as to remove man, very tight!!!
  • Posted 15 Oct 2022 05:10
  • Modified 15 Oct 2022 19:49 by administrator
  • By Forking_Around
  • joined 17 Jun'21 - 43 messages
  • New Zealand
it's been a long time since I worked on that crown model; If you have the service manual look in the parts breakdown.
you'll need to remove the drive unit subassembly, the bolts for the subassembly are easy to access once the drive wheel is removed.
be sure to drain out the gear oil, the drain and fill plugs are facing outboard, you can see them once the drive wheel is removed.
  • Posted 1 Aug 2022 00:38
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
edition #1272 - 12 March 2026
In this week’s Forkliftaction News , we report on the three inaugural CEOs who will manage the new materials handling entity of Toyota Automated Logistics when it launches on April 1... Continue reading
Eldo Verhaagen Eldo Verhaagen
Sales & operations director – material handling & agriculture Benelux, GRI
Director, dealer development Midwest & Southeast, Big Joe Forklifts
Director, Cyngn
Vice president people Americas, TVH Americas
Morooka MFD20
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
New Haven, Ct, United States
