SN: PI-00310
Anyone have info on code 292 on a woodward fuel system in this doosan,looked thru all the info i have and couldnt find this code,found 291 which has to do with the Throttle Position sensor,but nothing on this code.
Truck is running fine with no problems,cleared the code and didnt come back today,will check it again tomorrow but wondered what this code means???
Anyone have a PDF for this truck they could share??
Found out that code 292 also has to do with the TPsensors,is only in trucks with version 12 software or newer i guess from my contacts info,same troubleshooting as code 291. Truck still has a intermittant code can clear it and after a few days it comes back again as does code 291 sometimes,truck runs fine with no problems,just clear the codes and wait a few days and they/it comes back again
could be related to single backfire to inlet pipe. This affects electronic throtle operation and alarm comes ON. If this the case I would consider other LPG supplier (BTW the mixture for this model should be 90% propane and 10% butane)
Simon: My email address is in my profile,click on my name and it will show there,thank you
We've had a few of these machines that throw spurious error codes which never re-occur after clearing but it is worth checking the wiring to the mixer/throttle body. I have pdf's if you want to pass on your addresses.
I had the same problem as well. No info regarding 292. Please pass any info on to me also, thanks.
