Doosan G30P-3 Code 28
Hi!
The Engine start only if I drive the gear of throtle body manually.. I have code 28 in the selftest and the throthe body is doing is moving when I turn the key km(it open close open and close slowly)
Code 28 is ETC spring test failed?? The spring in the throtle body seam to be ok...
Does somebody can help me please? Servive manual??
  • Posted 1 Dec 2018 02:41
  • By Mike2000
  • joined 26 Oct'18 - 14 messages
  • Quebec, Canada
Was a faulty ECM, thanks all
  • Posted 17 Jan 2019 03:56
  • By Mike2000
  • Quebec, Canada
Mike2000 contact my profile, i may have some helpful info.
  • Posted 7 Dec 2018 05:18
  • By tom_p
  • Alberta, Canada
jroy500 @ hotmail dot com wiring diagram please
  • Posted 5 Dec 2018 13:01
  • Modified 5 Dec 2018 13:04 by poster
  • By Mike2000
  • Quebec, Canada
plugs and connectors seem to be ok but I checked continuity from connector to ECM and I have one wire who seem to go at a few place with resistance...is it normal?? I'm about to try with a brend new throtle body..maybe the tps is bad inside
do you have the wiring diagram??? G30P-3 GB-00260
  • Posted 5 Dec 2018 10:52
  • Modified 5 Dec 2018 13:11 by poster
  • By Mike2000
  • Quebec, Canada
Fault 26 Electronic throttle sticking.
Fault 27 Throttle position sensor value differs from SECM calculation
Fault 28 ETC spring or same as 26.
Above faults are frequently associated with throttle body open wiring
First check the wiring and plugs to and from throttle pedal.
Check for opens or disconnect on throttle body plug area.
Doosan's often have broken wiring where the harness connects to
the throttle body plug. Occasionally when running if the wires are
manipulated engine speed will change indicating an open.
  • Posted 1 Dec 2018 05:22
  • By tom_p
  • Alberta, Canada
Code 26 27 28 after I try to start
  • Posted 1 Dec 2018 02:47
  • By Mike2000
  • Quebec, Canada
Michel Denis Michel Denis
TCM FHD105Z
Manitou MH25-4
Lift Technologies Inc.
