display failure / lift function failure
Howdy all! Needing assistance in troubleshooting our UFS250. Display board has failed. (making further menu diagnosis quite difficult) Lift functions have ceased. All other hydraulic functions appear to be working. Our local dealer has gone quiet - no response to queries, etc. - wondering if it is our dealer, or the Atlet chunk from UniCarriers. These are more prevalent in Europe than in the States, any help from the Europeans would be greatly appreciated! Or, point me in the direction of a dealership with experience working on these.
Thank. You.
  • Posted 18 Jul 2017 09:30
  • By SmokedChops
  • joined 18 Jul'17 - 20 messages
  • Iowa, United States
Thanks for the response! the display failure was traced to poor ribbon cable connection between main control box and display module. (cable not seated squarely in 14p header connector.) Display is once again right with the world. Lift fault was in a programming menu - 'lift limit stop/restart' was unchecked for some reason in the system setup menu. [logged off - hit service button, select '3-authorised service', passcode [0002468] select '3-options' - items 3,4 'lift limit stop' and 'lift limit restart' should be checked "no" hopefully this keeps us going - and possibly helps someone else as well!
  • Posted 4 Aug 2017 10:42
  • By SmokedChops
could be a motor controller failure, is it a suaer danfoss controller, take the top cover off and look for burn spots on the circuit board
  • Posted 4 Aug 2017 09:24
  • By steppednit
  • joined 18 Oct'13 - 50 messages
  • Tennessee, United States
