Diagnosics Lap Top Kit Nissan K21 engine
unable to find a proper scan tool or lap top soft ware kit in order to access to computer data and fault codes < the truck runs good and then engine light comes on machine goes into limp mode still runs but goes right into idle only cycle turn key off start machine and runs fine for a few minutes and will do the same thing again can someone help us out here this machine is a real thorne in our side
  • Posted 12 Aug 2011 06:14
  • Modified 12 Aug 2011 06:16 by poster
  • By bryan
  • joined 19 Oct'10 - 9 messages
Normally for it to go into "Limp home mode" it is overheated (Code 33) or truck has a low oil pressure issue.
Nissan also has a service bulletin out about the transmission sensor on left hand side of the transmission getting wet and will do the same thing, just remove sensor,clean it good, reinstall and then silicone it to seal it.
Not real sure but check under the dash on right hand side, there may be a OBDll connector in the harness you can hook a good automotive handheld code reader up to, It'll give you a P code, but we can figure it out from there.
Don't your model, but do know Nissans quite well, is there any codes showing on the dash in the hour meter? I'll do what I can to help you out.
  • Posted 18 Sep 2011 13:11
  • By roadtech
Terberg TT223
Taylor TT300
USD98,500
October 12-15, 2026 - Detroit, MI, United States
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Terberg TT223
Taylor TT300
USD98,500
