Demounting foam filled tires
I am trying to demount foam filled tires that are too big in diameter to fit in my tire press. The rims are the traditional lock ring type. Assuming that I can get the lock ring off I assume that the foam in the tire is stuck on the rim. Any recommendations are appreciated.
  • Posted 17 Sep 2010 21:34
  • By duodeluxe
  • United States
duodeluxe
Duo, worked with a tire dealer for a while. Using a sawzall is the same way we removed all the old foam fills. The foam will stick to the rim some but not to bad. Good luck.
  • Posted 6 Oct 2010 06:50
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
Yeah, we figured out that the only way to get them off is to cut them off with a sawzall. It's pretty easy cutting through the tire but the steel bands are a big pain.
  • Posted 1 Oct 2010 21:20
  • By duodeluxe
  • United States
duodeluxe
around here, foam filled that have gotten glued to the rim are usually cut into smaller pieces with a sawzall and what ever is left cleaned up with a pneumatic or electric chiseler,
  • Posted 1 Oct 2010 20:05
IIRC foam filled tires have to be cut off the rim, they cannot be pressed off. I'll shoot you an email if i get some time to talk to my tire guy about how it's done.
  • Posted 1 Oct 2010 13:09
  • By steponmebbbboom
assuming it is a tube type rim, i would suspect tube is foam filled and it is not glued to rim itself, regular solid pheumatic directions would apply, if its a bead seal type rim then seek industrial tire company
  • Posted 30 Sep 2010 10:09
  • By vxtech
  • joined 10 Mar'07 - 9 messages
I would contact an industrial tire supplier. They have a special press with the proper tools to disasseble and install tires. It's worth the money for the time spent and frustration and SAFER.
  • Posted 17 Sep 2010 22:02
  • By Prentice
