Daewoo GC20E-3
Power steering quits working when lift is in gauged
  • Posted 22 Apr 2021 01:02
  • By Frank_Bolyard
  • joined 22 Apr'21 - 4 messages
  • West Virginia, United States
Frank Bolyard
Yea it's not a new machine but not everyone can afford a new one.
  • Posted 20 Aug 2021 00:56
  • By Frank_Bolyard
Frank Bolyard
CrownTech
A GC20E-3 is a fossil fuel burner
  • Posted 19 Aug 2021 20:01
  • By johnr_j
"Have An Exceptional Day!"
Thanks we checked the pump pressure it is ok looking at the priority valve now.
  • Posted 19 Aug 2021 19:45
  • By Frank_Bolyard
Frank Bolyard
I'd check the priority valve. Follow load sensing hose from steering unit (orbitrol) to find your priority valve >It's build in the main hydraulic pump. Chances are it's stuck in the position "lift".
When applying brake it could be that it gets in its normal position, Daewoo had a service campaign for this, i'd suggest getting more info from a local dealer.
  • Posted 10 Aug 2021 23:39
  • By Speedfreak
  • joined 24 May'18 - 103 messages
  • Niederlande, Netherlands
I don't have much experience with Daewoo but would say the steer motor is getting robbed of current. What is the battery voltage at rest and what is it during raise only? If it is a DC truck then how do the brushes and armature on the steer motor look? Are all the steer motor cables clean and tight?
  • Posted 8 Aug 2021 13:26
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Still need help with this problem. The steering shakes and becomes hard when I use the lift at the same time. Daewoo Dc20e-3 forklift
  • Posted 8 Aug 2021 05:20
  • By Frank_Bolyard
Frank Bolyard
Linde Material Handling
Terberg YT220
Taylor THC500L
