D156 error on screen
Hello. Does anybody know what means D156 error on a screen of Linde H45D forklift? The unit stopped working after this error appeared on screen. Thank you very much in advance
  • Posted 25 Oct 2014 00:19
  • By reshad_h
  • joined 25 Oct'14 - 1 message
  • Absheron, Azerbaijan
Hola estimado, tengo un linde E15 CON UN ERROR EN PANTALLA D156 Y ademas 3 iconos prenden, temperatura de motor, fallo eléctrica
  • Posted 15 Jul 2022 07:55
  • By Jhonatanperu
  • joined 15 Jul'22 - 1 message
  • Peru
Hi,
I'm having a problem with a Linde H30D
. Fault D156 on display when key on. Truck starts 9 out of 10 times when it starts fault disappears. Also sometimes you can't select direction. Any ideas?
Thx
  • Posted 8 Feb 2018 23:39
  • By jos_v
  • joined 17 Mar'17 - 8 messages
  • oost-vlaanderen, Belgium
jay dee it´s possible u can share the contact information of the Linde IC trainer i think it gonna help me a lot
sometimes i have a very especific question about IC trucks, i really appreciate if u can share the contac inf.
i just fixed a truck very far from our dealer after 3 long days of work cuz of this code,
tkx.
  • Posted 3 Mar 2017 09:25
  • By flbruno
  • joined 1 May'16 - 3 messages
  • df, Mexico
Our world always need a forklift....
Lift and traction are in the same controller so it is possible for the controller to be faulty.
D156 is a can bus error to the display.
Firstly I would be checking the resistance between the can Hi and Can low. Also check can wires for shorts to ground or pos.
Had many machine with a short to ground due to damaged insulation on the can bus wires.
  • Posted 27 Jan 2017 13:38
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Hi I have the code d156
engine will not start
I have had a chap in to do diagnostic and he cannot communicate with either traction or lift controller.
But we are getting a feed to the canbox from forklift.
I'm sure both controllers would not have died any ideas?
Cheers
Linde
H35t
939
  • Posted 19 Jan 2017 02:15
  • By Deacon222
  • joined 19 Jan'17 - 1 message
  • Somerset, United Kingdom
gday jay dee it would b great if you could send me that fella's details even if just for future reference. cheers
  • Posted 6 Aug 2015 08:24
  • By gozza
  • joined 5 Aug'15 - 4 messages
  • New South Wales, Australia
life wasn't meant to be easy
All good Gozza, I used to be based in Newcastle at sandgate with Komatsu, now Im with Linde, I can give you a contact of a Linde IC trainer based in Brisbane who is only too happy to help anyone in need, awesome guy always willing to share his knowledge. Let me know and I'll flick you his details.
  • Posted 5 Aug 2015 20:05
  • By jay_dee
  • joined 2 Oct'14 - 21 messages
2 heads are better than 1
Thanks heaps JayDee. I've been trying to get info on this truck all day. I've performed all the usual checks you've outlined above also. I was starting to look at the controller. But wanted a bit of confirmation before I went to the expense. I'm in Newcastle and no I'm not a Linde tech, I was a Crown tech for 6 years, I work for a small company these days. Thanks again.
  • Posted 5 Aug 2015 17:25
  • By gozza
Yes Gozza, all 3 leds where on when fault appeared, and both were H25t trucks both were 392's, one with 7800hrs and the other with 8800hrs. did the usual checks, plugs, harness, resistance, pin contact ,continuity etc, Had my local IC trainer evaluate fault and we ended up ordering replacement controllers from Germany. As soon as we powered up m/c code disappeared immediately and are still performing fault free. Thank goodness they are rental m/c's as I would hate to think what they would cost. Where in NSW are you ? Are you a Linde tech ?
  • Posted 5 Aug 2015 16:55
  • By jay_dee
Jay Dee did the trucks you replaced the controllers on have the 3 LED's for oil temp, engine temp and electric circuit problem illuminated? and does the same fault code apply to 392 series H25 trucks?
  • Posted 5 Aug 2015 15:32
  • By gozza
can anybody give me some guidance on the location of the 6x1 &x15 connectors? thanks in advance
  • Posted 5 Aug 2015 15:26
  • By gozza
D156 error on display, disconnect battery for 30 secs then reconnect to reset or remove error code from display,truk should function after this, if it reappears, yu have a faulty controller. Remove controller and replace,have had to do 2 of these recently as requsted by Linde Trainer from Germany. Faulty batch of controllers.
  • Posted 16 Jul 2015 19:20
  • By jay_dee
The D156 error on 39x trucks applies to display problems.
it may be:
Connector 6x1 - defect
Connector X15 - defect
The whole display defect.
If the error occures, you should have the following LEDS on:
H1 (Oil temperature)
H4 (Electric circuit problem)
H5 (Engine tempertaure)
  • Posted 30 Oct 2014 20:20
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
