Curtis controller 1244-4417 parameter for a Raymond Pacer
Hi,
Can somebody help me to find out the parameter I have to set in a traction Curtis controller 1244-4417. This controller is used in a Raymond Pacer forklift. I have been looking around with no success.
Thank you
Luis
  • Posted 20 Jul 2007 08:31
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
I do have the programmer 1311-4401. Good to know you can help in Curtis controllers. Do you knoe if the 1207-1101 can substitue the 1207-2103? this is because I am in my way to get some 1207-1101 and the suplier told me they can be programmed as 12072103. is that possible? can you help me about it?
Thank you
Luis
  • Posted 27 Jul 2007 11:41
  • By luis_v
  • Mexico
i don,t have raymond spec only got curtis spec. but u need curtis 1311-4401 controller to change paramaters even then no defolt parm all set to your spec. if u need info on parm or fault codes where curtis unit is conserened i can help
  • Posted 27 Jul 2007 11:27
  • By milo
  • joined 13 Jun'07 - 19 messages
  • dublin, Ireland
I would like to set the controller as it was form the dealer Raymond (Pacer model: R40C40QM). There has been several untis changes and I really do not know if all they are setting up correctly.
In fact, I need all specific Raymond parameter
Thank you
Luis
  • Posted 27 Jul 2007 10:52
  • By luis_v
  • Mexico
what parameters do you want to change
  • Posted 27 Jul 2007 10:35
  • By milo
  • dublin, Ireland
Go to curtisinst dot com/index.cfm?fuseaction=cProducts dot DownloadPDF&file=ACFWC9e9x%2Epdf
  • Posted 23 Jul 2007 00:48
  • By Truck_Tech
  • United States
