crown sp3020-30 brakes won't release
Units brake doesn't release with deadman, tested brake module and all voltages on test points match those of table in service manual, replaced magnetic coil and brakes still don't release. Leaning towards brake module but not 100% sure. Tow switch doesn't even actuate magnetic brake. Any thoughts?
  • Posted 7 Nov 2018 07:29
  • By jack_d
  • joined 7 Nov'18 - 5 messages
  • Wisconsin, United States
Checked the upper gauge in brake assembly is correct
  • Posted 12 Jul 2019 06:27
  • By cesar_c
  • joined 12 Jul'19 - 2 messages
It ended up being the brake module, tested good at all test points and fault LED wasn't lit up but it wasn't actually outputting to the coil. Installed rebuilt brake module and it works perfect now.
  • Posted 20 Nov 2018 06:11
  • By jack_d
I will check that next time I am in there, thanks for response.
  • Posted 8 Nov 2018 02:54
  • By jack_d
Try checking CA209 on the dist. board, I've had pin 3 burn a few times in the past.
  • Posted 8 Nov 2018 02:08
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Lift Tek Elecar
Philadephia, PA, United States
Chandler, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Toyota 3FD100
UN Forklift FB25N1LZ1
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
