Crown RD 5000
I have a Crown 5000 RD that the forward reverse handle works opposite than is intended.Is this a function I can reverse in the "calibrate" mode or must I reverse the optical for./rev. switches physical location.I will be working on this soon and will post if I find the solution.
  • Posted 18 Mar 2005 13:59
  • By Jules
  • joined 14 Jan'05 - 9 messages
  • Rhode Island, United States
It seems the harder I work,the more lucky I become.
Hey Guys,
Thanks for the input.I tried running the calibrate mode and had no luck,it kept coming up "invalid" so I tried reversing the the wires with no luck again,but as luck would have it I pulled a wire out of one of the optical sensors(I think it was ready to before I finished it off).I replaced the optical sensor/board assy.,and the problem is solved!!
Jules
  • Posted 7 Apr 2005 07:09
  • By Jules
I heard a salesman did this one time. Go into the calibration mode and calibrate the travel pot. It is possible you have cables switched to the drive motor, but I think the contoller will sense this and lock the brakes.
To calibrate, you just get to the travel pot calibrations and hit the enter button (also called the return key of the 90 degree bent arrow button. You push the handle forward, hit enter, push it to the center and hit enter, then reverse and hit enter. You will then have to get to a place where you escape back to the main menu and it will ask if you want to save the new settings. You want to scroll up to where it says yes and hit enter and that should do it. If you have the standard disply where it is just giving numbers instead of actual words that tell you where you are in the menu, I will have to go into more detail or you need a book. Also, the diagnostics on this truck will allow you to look at all the switches. This will tell you whether the forward and reverse switches are closing and opening properly when you push the handle forward and reverse. This is the " analyzer" mode.
  • Posted 19 Mar 2005 13:34
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Maxlion FDR50
Maxlion FD30
