Crank No Start
Doosan D35S-5 with an inline 4 diesel forklift will crank and won't start, if you put a shot of ether in it, it will fire up and run with 0 problems. I feel as if something is telling the injectors not to fire as they are electronically fired. I have ordered a new crank and cam sensor. I pulled an injector turned it around hooked it back up and they are not spraying on crank. I do not have any way to scan the codes if anyone has any insight on what I need to do that I would appreciate it as it will likely lead me in the right direction. Any help appreciated thank you
  • Posted 2 Apr 2025 07:46
  • By RickDozer
  • joined 2 Apr'25 - 1 message
  • Iowa, United States
Hi, As far as I understand, the forklift has a Hyundai D439 engine. In order to understand the fault with the engine, you need to connect the G-Scan diagnostic tool to the forklift.
  • Posted 29 Jun 2025 04:52
  • Modified 30 Jun 2025 10:14 by administrator
  • By marksmith
  • joined 26 May'25 - 17 messages
  • United Kingdom
forkliftmanual.com
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hoist Liftruck F180-36BOX-CAR
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
