Crank No Start, weak spark
I have a hoist fr 40/60 3.0l that is a crank no start.
The ignition coil, plugs, wires, cap and rotor, were replaced and we still have almost the same conditions. There's a service engine light but there is no way for us to retrieve the codes that I'm aware of.
The only thing I'm seeing off is only 9v at the ignition coil power wire and have no damaged wiring or blown fuses. Is it possible the computer is not sending a good signal to the coil?
I'm running out of ideas and resources so any help would be appreciated.
  • Posted 18 Apr 2023 02:28
  • By Justin_Green
  • joined 18 Apr'23 - 1 message
  • Wisconsin, United States
Did you get this figured out?
  • Posted 5 Jul 2023 00:00
  • By John_Lizzadro
  • joined 4 Jul'23 - 1 message
  • Illinois, United States
John L
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
