Counterbalance 16 and 32 Tonne Fork Trucks
Good evening all I am looking for some advice and some useful tips on driving the 16 and 32 tonne CB fork trucks.
I am a complete novice to fork trucks I started a 4 day course on Monday snd have my test on Thursday.
For the most part everything seems to be going well and alot of training has been fantastic but I am struggling in one area only and that is putting a load down. I either use too much tilt or not enough.
If anyone can help or give advice on the best way to judge how much is enough tilt by giving examples in references in the mast etc I would certainly appreciate this.
Many thanks and Kind Regards
  • Posted 25 Jul 2018 05:38
  • By SJB01
  • joined 25 Jul'18 - 1 message
  • United Kingdom
Just double checking - they were 16 and 32 ton forklifts?!?! ( not 1600kg and 3200kg??) Virtually unheard of to hear a forklift training organisation training new operators on forklifts that big....nonetheless like the previous answerer has said, almost every forklift operator has had trouble learning how to judge tilt, the best ways iv'e found is to get the forks flat/"mast vertical" on the floor and /or at eye level when your'e getting a load from the racks....also comes with experience, but by looking at the mast you should also be able to see if its tilted forwards or backwards....very hard to get it perfectly level, but close enough is usually good enough if your'e dealing with wide pallets like euro pallets, loscam and chep pallets (what we use in australia).... the thin export pallets are an absolute pain!!!
Also as much as you'd like to use something to help you leveling the forks, i'd recommend against it to start off with as its best to learn how to do it by eye in my opinion, you won't always be having perfectly flat floors in every loading/unloading scenario so youl'l have to learn to adjust your tilt backwards or forward to get flat forks (if that makes sense lol)
  • Posted 3 Aug 2018 02:39
  • By z_n_a_n
  • joined 14 Apr'17 - 2 messages
  • Victoria, Australia
SJB01, you're not alone in having difficulty judging the mast tilt angle, I think every FLT driver has the same problem because it's due to the fact that the driving position does not give any vision of the side of the mast or forks.
In training for smaller CB's I was told to lift the forks to eyelevel as this gives you the best chance of getting anywhere close to levelling the forks. However, it is still very inaccurate, does not work if your not on a perfectly level floor, and anyone who did this at work would be criticised for time wasting. And obviously it doesn't work at all when you have a load on the forks.
The best solution is to have your truck fitted with a mast tilt indicator so you know for sure that the forks are level before you pick up or put down a load.
There are several types available, but the best by far is the SUMOLevel available from SUMOSafe.net. Not only is it the most accurate, allowing you to level the forks to a fraction of a mm along their length, it is also very simple and clear to use.
  • Posted 1 Aug 2018 23:41
  • By antony_c
  • joined 16 Jul'15 - 3 messages
  • Cheshire, United Kingdom
Hoist Liftruck F180-36BOX-CAR
Still GX10
Still GX10 2000
Poland
EUR950
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
May CapEx Index falls Washington, DC, United States
November 3-4 2026 - Houston, United States
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Still GX10
Still GX10 2000
Poland
EUR950
