Common Electromagnetic Holding Brake Voltages
What would you say are the most common controller's brake output voltages for electromagnetic holding brakes?
  • Posted 6 Jun 2009 09:56
  • Discussion started by solo
Sorry, I think my question was not clear.
Electromagnetic holding brakes have voltage ratings. I would like to know what are the most common voltages used.
Thanks.
  • Posted 9 Jun 2009 01:43
  • Reply by solo
and they are spring loaded so the "holding" (stopping) voltage is 0 vdc, while battery voltage is most often used to release the brakes. there is far more likely that the air gap is too large or too small if you are having problems.
  • Posted 6 Jun 2009 21:57
  • Reply by edward_t
Hi Solo
Usually the brake Has a positive voltage supplied by either the key switch or an interlock switch(like a tiller switch or dead man switch) and the controller supplies the negative.
Hope this helps.
Shane
  • Posted 6 Jun 2009 19:51
  • Reply by controlelectric
  • Shropshire, United Kingdom
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
