Collecting accurate hour-meter readings.
Hi, first post here. I am an auto electrician servicing the electric forklifts at a factory in New Zealand.
We currently have tracking devices on all our forklifts and are working on connecting them to an app that trigger requests for a service at the correct time.
I am told that our forklifts generate their hour meter readings based on the traction control ECU.
How do we tap into these readings to get an accurate figure please?
At the moment the system generates its reading based on ignition time which means that is very different from the correct reading.
Even if we could find out where to pick up a connection to our tracker box to use that signal for time measurement that would be good.
Thanks in advance :)
  • Posted 24 Mar 2023 08:54
  • By Desmond_Downs
  • joined 24 Mar'23 - 1 message
  • New Zealand
Desmond
I assume you have this straight by now. A serial number of lift would help as each year or model is different. Some hour meters list key, electric motor and hydraulics. Good Luck
  • Posted 2 Jun 2023 02:31
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
