Yale GLC050VXNVSE083:
Codigo de falla 522762-4
Me pueden apoyar con este código por favor y a qué se refiere 522762-4
Littoral Translation...
Can you help me with this code please and what does 522762-4 refer to?
Please use English Language
  • Posted 8 Aug 2024 08:52
  • Modified 8 Aug 2024 15:29 by administrator
  • Discussion started by Sofo
  • Mexico
David G. C.
Sofo,
Ignition 3 voltage is low. First check battery voltage when trying to crank engine. Check fuses 6 and 7 to make sure they are reading battery voltage. Swap relay 1 with relay 5 and see if code changes. This means the relay has failed. Remove each connector at the fuse box and check for corrosion and good connections. Good Luck.
  • Posted 19 Aug 2024 23:27
  • Reply by Fishmech
  • Virginia, United States
edition #1234 - 12 June 2025
