codes a6-1,a6-3 , 63-1
Have these codes at start up.A6-1, A6-3, 63-1. No hyd function..have Changed lift and tilt switches have new harness, Cpu , hyd motor. Book says adj switches but no ajustment for tilt switch Could I have put the new tilt switches on in the wrong location as they are conected to 1 connector. Travel not affected. Also bdi flashes all segments. Battery is known good.
  • Posted 10 Feb 2013 03:17
  • Modified 11 Feb 2013 21:43 by poster
  • By stevepops
  • joined 22 Dec'12 - 10 messages
  • Oklahoma, United States
im getting a constant code 31...it used to happen here and there now it is like 90% of the time it throws this code alarm sounds and lift wont move. If any one knows what could be the possible causes that would be greatly appreciated.
  • Posted 21 Sep 2016 22:29
  • By Gator
  • joined 3 Oct'14 - 45 messages
does a toyota 6BRU18 have battery as well?
  • Posted 21 Sep 2016 22:25
  • By Gator
I believe that there is a kit so you can replace the display battery. Fixnproblems is correct that it does cause multiple false codes when that battery dies.
  • Posted 16 Feb 2013 10:09
  • By rogeriwt
I have ran into this similar problem. There is the display and under that a display card.(attached in the same white box) I have had to change the display card numerous times because there is a 3.6 volt lithium battery soldered into it that goes dead after awhile and causes multiple codes to appear. I would swap that card out with a known good one.
hopefully this helps you out.
  • Posted 14 Feb 2013 13:09
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
US confidence index rises sharply Washington, DC, United States
July 9-10, 2025 - Birmingham, United Kingdom
St. Louis, MO, United States
Uxbridge, Canada
Evansville, IN, United States
Daleville, IN, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
