Code truck disabled
524245-3 is the code installed a new seat switch any help would be appreciated.
  • Posted 26 Mar 2013 03:37
  • By alan_d
  • joined 11 Sep'11 - 7 messages
The seat has a 6 pin connector harness which runs thru the engine cover the harness from the truck side has a 6 pin and a two pin connector.
  • Posted 26 Mar 2013 07:40
  • By alan_d
I'm a bit confused. Does the new seat have a switch in the bottom of it with wires coming out of the switch and a 2 pin square shaped connector on the end of the wires? That should connect to the 2 pin connector from the forklift that comes through the hole in the engine cover, right under the seat. Where is the 6 pin connector, inside the engine compartment?
  • Posted 26 Mar 2013 06:04
They purchased the truck from an auction with no seat on it now I'm stuck trying to figure out what is wrong with it the plug, 6 pin is the same but there is a two pin that is on the truck that is tied off to the harness that goes to the seat switch bu no where to plug it in the seat.
  • Posted 26 Mar 2013 05:47
  • By alan_d
Did the truck stop working after you changed the seat? Is the wire harness plug on the new seat the same as the old one?
  • Posted 26 Mar 2013 05:43
It was a replacement seat from Yale how would you know the difference I know the difference?
  • Posted 26 Mar 2013 05:30
  • By alan_d
Did you use the special $100 Yale proximity seat switch that is used on these trucks? It is not a simple standard on/off seat switch like most other trucks have, even though they look the same.
  • Posted 26 Mar 2013 05:19
2 wires ? 5 volt signal?
  • Posted 26 Mar 2013 04:09
  • By alan_d
2 wires 5volt 1 wire signal. between+5volt and signal resitant or dash lamp to disconect
  • Posted 26 Mar 2013 04:01
  • Modified 26 Mar 2013 04:08 by poster
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Taylor T520M
Terberg RT223
VETTER Industrie GmbH
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
