Code FH
Do i need to check for any other than replacing the card?
Code FH start up and shut down with the code.
any help would be great
  • Posted 8 Oct 2020 08:54
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
i believe FH means Battery Voltage out of range
Wrong voltage battery or voltage out of range.
Says to run test A-15
Battery sense voltage at JPT24-24 must read within a range of:
24v truck = 22.0 to 26 volts
36v truck = 33.0 to 39 volts
diagnostic says to test at
step 1: TP1 (+ lead) to TP4 (ground) if pass go to next step, if fail check batt voltage/SG
step 2: JPF4-1 (+ lead) to TP4 (ground) if pass go to next step, if fail check harness TP1 to TP4.
step 3: JPF4-7 (+ lead) to TP4 (ground) if pass go to next step, if fail replace fuse relay card
step 4: JPT24-24 (+ lead) to TP4 (ground) if pass replace VCM, if fail check harness from fuse relay card to VM.
expected voltage on all tests are:
24v truck = 16 to 32v
36v truck = 28 to 44v
  • Posted 8 Oct 2020 22:32
Still GX10
Still GX10 2000
Poland
EUR950
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Zhejiang UN Forklift Co., Ltd
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
Stu Jacover Stu Jacover
Chief executive officer, TVH
