Code 65299
I'm getting code 65299 and the control will not turn on.
  • Posted 5 Jun 2015 07:28
  • By SouthernTech
  • joined 5 Jun'15 - 1 message
  • Alabama, United States
Hi I am getting a error code 12941 forklift details are HYSTER, J2.0XNT, K160 SERIES YEAR 2011. Can any one help me what does it mean ?
  • Posted 4 Apr 2018 16:19
  • By SAF_B
  • joined 26 Oct'16 - 13 messages
  • dubai, United Arab Emirates
saf
65299 indicates controller logic failure
make sure the battery voltage is correct (check battery for good charge, make sure there are no bad cells)
also the battery voltage in the logic needs to be set to the correct voltage, if it will let you enter diagnostic mode then check the voltage setting.
inspect battery connections and also inspect connectors to VSM for bad connections.
  • Posted 5 Jun 2015 21:19
July 9-10, 2025 - Birmingham, United Kingdom
St. Louis, MO, United States
Daleville, IN, United States
Uxbridge, Canada
Evansville, IN, United States
Uxbridge, Canada
Uxbridge, Canada
