code 64 on toyota
Can anyone tell me what a code 64 is on a toyota 7fgcu30 serial#60604 Thanks
  • Posted 4 Dec 2008 01:35
  • By PR2005
  • joined 18 Mar'06 - 23 messages
  • Illinois, United States
Yeah, or somethings is jammed in there by the tilt cylinder, Thanks Cooter
  • Posted 18 Dec 2008 07:52
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Code 64 is a Tilt solenoid 1 abnormality.
The tilt solenoid should be aprox 10 ohms at the solenoid.
If you want to check the complete circuit remove connector 1 from the the SAS controller should be 26 pin connector. Check from pin 13 light blue wire to pin 24 white with a black stripe.
  • Posted 18 Dec 2008 06:23
  • By Cooter
  • joined 18 Dec'08 - 1 message
  • Indiana, United States
Thanks Rich
  • Posted 11 Dec 2008 07:20
  • By PR2005
Code 64 is for the SAS it is either the height switch, switch on right side tilt cylinder or pressure switch in middle of mast. Rich
  • Posted 5 Dec 2008 08:41
  • By rich_k
Aichi RX07B
Taylor TE650S
Lift Technologies Inc.
