code 524223-0 reverse and 524225-0 forward
hello i have a hyster h50ft serial l177 wit basic transmission aluminium and i have a problme wit transmission forward and reverse me check the voltage transducer i have 5.02 v each tranducer and change the transducer i have same probleme help me please bye Jack
  • Posted 13 Apr 2014 10:32
  • By jacques_b
  • joined 13 Apr'14 - 2 messages
  • Quebec, Canada
Hi edward, yes my transmission problem is that it falls forward as neutral as back in my display pressure reading is 179lbs is it possible that the problem is in the transmission, the transmission valve body has no it is basic transmission are there any pressure regulator available
the problem happens when the truck rolls at high speed forward or revers thank you very much edward
  • Posted 15 Apr 2014 12:02
  • By jacques_b
  • Quebec, Canada
please describe for us further what the symptoms are to the transmission, [how it drives that made you decide to change the "transducer"}.
524223-0
XMSN Reverse Pressure Greater Than Commanded Pressure
524225-0.XMSN Forward 1 Pressure Greater Than Commanded Pressure
  • Posted 13 Apr 2014 22:57
Toyota 8FD45
Taylor THC500L
Toyota 8FD45
Taylor THC500L
