Hyster S50FT:
Code 522655
We have a S50FT F187V06547D unit that has a Temperture Fault that pops up on the dash. The code is 522655. Can anyone tell me what this could be?
Thanks
Andy
  • Posted 30 Aug 2012 01:42
  • Discussion started by chevelless502
  • Illinois, United States
This code comes up when the engine has idled for too long as well when the fault shows drive the forklift like normal & it will go away. If you have a machine that allows you to check fault logs you will see it regularly. 660 logs on a machine with 2457 hrs. Nothing at all to worry about unless it is showing up in normal operation.
  • Posted 25 Oct 2015 13:18
  • Reply by badgav
Go hard or go home.
the description of your code is in the post just above this one.
start with clearing the code and seeing how quick it returns, then making sure your air filter is new, and has not been blown out too many times, then do a good tune up.
  • Posted 21 Mar 2014 20:04
  • Reply by edward_t
522655-1 code. What does that mean and how to I repair it?
  • Posted 21 Mar 2014 07:33
  • Reply by sako_k
Sako1sk at yahoo dot com
522655-0 short term closed loop correction bank 1 less than nor.-40% ritch e.op. 522655-1 short term c.l.c bank greater than nor+40% lean e op
  • Posted 31 Aug 2012 03:58
  • Reply by AAPEE
  • Brussels, Belgium
Terberg YT220
Ncn 110TH
Ncn 110TH 2023
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
