code 51-7
Just wondering what code 51-7 refers to on this Yale. Engine will not idle up.
  • Posted 25 Mar 2011 23:39
  • By MikeMan
  • joined 8 Feb'11 - 17 messages
  • Iowa, United States
(if your able to...)Go into dash and check the accell sensor... Make sure it has signal on both A and B. Make sure sensor has voltage to it. Check to see it has a consistant sweep as you push accelerator. You can do the same at the sensor if needed.
This code is saying your accel sensor and throttle sensor aren't tracking within 15%. Hope it helps. (If I had to guess I would say you have to replace the accel sensor on pedal.)
  • Posted 27 Mar 2011 12:33
  • By marvin_g
  • joined 21 Feb'11 - 25 messages
  • Kentucky, United States
