Code 48
Does anyone know how to cure a code 48? I think this is a contactor issue for forward and reverse? Can someone confirm.
Thanks
  • Posted 7 Apr 2008 16:02
  • By peter_t
  • joined 7 Apr'08 - 3 messages
  • Virginia, United States
tell me more about the fan kit please 40fctt-188 overheating alot
  • Posted 15 Nov 2008 05:04
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
Can you give me the model#
Scratch prior....
Code 48- most of the time it's just the contactor coils that have built up a little resistance causing a slower pull-in time. Also check the pintle ( stem ) on the rear of the armature, if it's broken off it will not guide in well. When I rebuild these I clean all parts with contact cleaner before reassembly. If these contactors have the filters on them, check the resistance. I have replaced 4 or 5 in the past year. If you suspect the contactor - replace it. Code 24 & 48 are more common if the FC. I would guess it is due to the higher drive motor draw. There is also a fan kit available that cools the contactor panel- good for rough applications.
  • Posted 9 Apr 2008 10:47
  • Modified 9 Apr 2008 11:13 by administrator
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Lift Tek Elecar
Lift Tek Elecar
