Code 35
Check engine light on, found the procedure to pull code from dash in another thread and have a reoccurring code 35.
Backfires intermittent upon startup. Cleared the code but it returns.
What is 35?
Recently replaced spark plugs, lp filter, has a new electric throttle body, the gear teeth were stripped off from the backfires
Please help.
  • Posted 26 Jan 2017 03:22
  • By Keithr
  • joined 26 Jan'17 - 1 message
  • Wisconsin, United States
Hey man you are reading the code wrong its a 353 code which is an issue with the tmap, either the sensor is bad or there is a break in the wiring.
  • Posted 3 Mar 2017 12:31
  • By drew_b
  • joined 3 Mar'17 - 3 messages
I can find no fault 35 in the doosan list. Be sure to change the PCV (use doosan PCV) valve and confirm all vacuum lines and hoses are intact. What engine and fuel system do you have? If Woodward, check mixer diaphragm for damage or wear.
  • Posted 21 Feb 2017 04:48
  • By tom_p
  • Alberta, Canada
Michel Denis Michel Denis
