code 29
The truck drives fine for about 10 feet the cuts off and gives a code 29 any idea what a code 29 is
  • Posted 9 Apr 2013 12:34
  • By robbiekds
  • joined 5 Apr'13 - 7 messages
every time when you have a 29 code....the problems can be on the sensor, the wire or tractor manager.....this code can stay saved on vfc card.....check the distance between the read disc and the velocity proximity sensor this will be on 1mm of distance after that reboot the vfc card codes, turn on the key switch and accelerate the truck for a few moments....after then releace the traction joystick and remake the prove and done!!! the code is over.
mauricio Tapia
from chile
  • Posted 25 May 2013 13:04
  • By mauricio_t
  • joined 25 May'13 - 2 messages
  • santiago, Chile
check the gap between the speed sensor and the disc above it if that gap is to lardge or the disc is rubbing you can get a code 29
  • Posted 26 Apr 2013 06:04
  • By forktech418
  • joined 31 May'12 - 19 messages
code 29 is no movement detected when requested.
basically you are asking the truck to drive but it does not see itself moving.
check your brake assy and coil and wiring. also the speed feedback sensor cabling, it is mounted on top of the brake underneath a disc that passes over it to generate a speed/direction signal.
  • Posted 9 Apr 2013 19:10
  • By stam
Terberg YT223
Taylor TX175
New - Sale & Hire
F. Uchiyama
Terberg YT223
Taylor TX175
New - Sale & Hire
Terberg YT223
Taylor TX175
New - Sale & Hire
F. Uchiyama
