Code #2
Customer complains that forklift back fires severely then stopped running. Found badly corroded distributor. Replaced distributor. Now runs but hard starting when warm. Starts fine when cold. Blink code #2 becomes active after a few minutes of throttle operation. Changed all propane system including tank, hoses and converter. All ignition is good and in time...I believe. Changed out throttle sensor with a known good sensor and code still becomes active. Is this a straight forward throttle body replacement? Or should I be chasing a different source?Any help, please
Make: Toyota
Model: 7FGU30
Ser: 61479
Engine: 4y ECS
  • Posted 27 Jun 2013 07:03
  • By paul_r
  • joined 27 Jun'13 - 5 messages
  • British Columbia, Canada
I tried to exchange a known good pedal and still coming up with same error code. I check all connections and wiring with no luck....I may be looking at a service call from the toyota guy to sort this problem out. thanks guys.
  • Posted 3 Jul 2013 02:14
  • By paul_r
Open or short circuit signal from
acceleration sensor
I would start by checking the wires at the connectors.
  • Posted 29 Jun 2013 11:28
  • By rogeriwt
I ain't no Toyota ECS ex-spurt, but I bet you will need the (Toyota propriety) handset to set the pot in the step to match the throttle body.
  • Posted 27 Jun 2013 21:06
Kalmar DRF450-70C5XS
SMV (Konecranes) 20-1200B
Michel Denis Michel Denis
