Code 135-16
Can someone tell me what this fault code is? Thank you
  • Posted 23 Mar 2013 02:50
  • By DanD
  • joined 18 Jul'12 - 9 messages
no Dan we do not, at least not exactly, California has thier own strict standards but from the trend I've been seeing in the emissions standards emerging now they are adopting more and more stringent standards that fall along the same lines as California.
  • Posted 27 Mar 2013 23:54
Swoop223 I'm sure we do on the lap top. Do you have the same emission standards as California? Thanks for your help swoop223
  • Posted 27 Mar 2013 09:06
  • By DanD
I just put my E Mail address in my profile. Thanks Kevin t
  • Posted 27 Mar 2013 08:54
  • By DanD
Dan you have an email to post in your profile for some info??
  • Posted 26 Mar 2013 06:17
  • By kevin_t
MAP stands for Manifold Absolute Pressure so yes it has to do with intake manifold pressure.
It could be your MAP sensor is bad or has a broken wire in the harness at the plug... this has been fairly common when these codes occur.
Of course it may be some other problem causing it, i would use the troubleshooting guide to set you in the right direction.
  • Posted 26 Mar 2013 02:38
  • Modified 26 Mar 2013 02:39 by poster
OK is the MAP sensor bad? Doesn't the MAP have to do with the intake air?
  • Posted 26 Mar 2013 01:40
  • By DanD
DTC 135-16
Fuel Absolute Pressure Minus (MAP) Too High
  • Posted 25 Mar 2013 19:24
  • By kevin_t
Sorry about that, H90FT P005V04358J. Thanks again
  • Posted 25 Mar 2013 10:42
  • By DanD
a serial number of truck would help alot
but from looking at 2 of the 4 different serial number ranges for this model truck this code refers to Fuel Pressure.
without serial number we cannot be accurate on information
  • Posted 24 Mar 2013 00:22
throttel error
  • Posted 23 Mar 2013 19:38
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Terberg YT222
Unicarriers FD80-2
Yale Lift Truck Technologies
