code 11
Code indicates depressed accelerator pedal ( I think ), Customer found and removed cracked micro switch a pedal. I installed new switch and adjusted. The unit worked fine for 10 min then same code. Switch checkes out ok.
Any ideas
Thanks Ted
  • Posted 10 Aug 2012 23:57
  • By BrewCrew
We`re here for a good time
back to the basics.
1 key up truck and check the voltage at the distribution board CA 205-3 (should be 0 volts)
2 check voltage at both the master and slave controller. CA 401-3 and CA403-3 if you have over 18 volts then the calibrate the ACC and brake pot you need a handset and manual to do this. It's the regular handset used on all EV 100 systems.
  • Posted 6 Apr 2017 09:29
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
trouble code says if you have less than 18 volts which I had zero on pin three on the connector at module and replace the module. I have 36 volts when the accelerator switch is depressed at pin 3 and 0 volts when it is not depressed.
how do you calibrate the accelerator pot?
  • Posted 5 Apr 2017 09:56
  • By BigAl88246
  • joined 5 Apr'17 - 15 messages
Calibrate acc pot and brake pot
  • Posted 7 Mar 2015 09:09
  • By troy_m
SMV (Konecranes) 33-1200C
Mitsubishi FGE35AT
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
