Code -06 and -74
Good afternoon,
I have a hyster E50XM that stops on occasion when you try plugging. It reads -06 then -74 and locks up and wont do a thing. Thoughtsor suggestions? Contactors are new. I do not have a manual. Thanks i advance everyone!
  • Posted 9 Jun 2020 05:16
  • By torie_m
  • joined 9 Feb'19 - 3 messages
  • Missouri, United States
Thank you! I appreciate the response!
  • Posted 17 Jun 2020 03:27
  • By torie_m
Those codes make it look like you have a EV100 LX system. If so, -06 means the accelerator was pressed with no direction selected.
-074 SYMPTOM
Forward or reverse contactor opens and closes, then opens and can only close by opening and closing the key switch.
POSSIBLE CAUSE
Defective RB contactor.
? Check RB contactor for smoothness of operation
and excessive wear on moving parts.
Intermittent PA6 input.
? Check for loose connections in PA6 circuit from
PA6 to RB contactor A2 connection.
Defective RB contactor coil circuit.
? Check RB contactor coil for proper ohmic value. It
should be 10-14 ohms.
? Check coil connection from PB2 to RB coil (-) for loose connections.
? Check coil connections from battery positive to RB coil (+) for loose connections.
You can get EV100LX documentation from the Flight Systems website.
I'd tackle the -06 problem first. If your directional control circuits are unreliable that could affect the regen braking as well.
  • Posted 12 Jun 2020 01:05
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
Aichi RX07B
Crown CG33P5
