Clark GPX25E Missing
New to the page trying to figure out a problem with our fork lift. When starting the fork lift it run fine for about a minute as soon as you move or get up to any amount of speed it starts to misfire. I have pin pointed the misfire to cylinder 3. Are there valve adjustment to be made on these engines. This is a Mitsubishi Engine that is in the machine. Spark plugs, wire, cap and rotor have been changed. Any help would be greatly appreciated.
  • Posted 25 Apr 2024 05:39
  • By Devin_Loose
  • joined 25 Apr'24 - 2 messages
Clark GPX25E with Mitsubishi Engine
I have not. That was going to be my next checking point. It very weird. It starts fine and runs good for about a minute or two. If I go across the lot at full speed it will start to miss. Turn it off and let it sit for a few minutes it starts up fine like nothing ever happened. Will check compression and get back and let you know results.
  • Posted 25 Apr 2024 21:26
  • By Devin_Loose
Valve adjustment is hydraulic, they are prone for sticking valves. Have you done a compression test? I had one it used to run fine but once hot it dropped onto 3 cylinders. Once it did this if you stopped the engine and restarted it you could here it was down a cylinder when cranking. It was a sticking valve.
  • Posted 25 Apr 2024 21:12
  • By andrew_k
  • joined 17 Mar'07 - 359 messages
  • England, United Kingdom
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
VETTER Forks, Inc.
