Clark CMP25L - Inching brakes binding
I recently replaced the inching and master brake cylinders on a CLARK CMP25L fork, now the operator complains that the brakes are binding.. stops the fork, and prevents its moving until the unit has "cooled down".
Quoting the operator - "the brakes seize and become tight at the pedals when the fork gets hot"
I'm thinking this issue is with the inching brake and not the wheel/drum brakes. I also notice that the transmission fluid get really hot real quickly - even after a short operation. Can spent transmission fluid cause this problem? Is it that the radiator coolant passes are getting blocked?
There's no complaint or evidence of engine overheating.
  • Posted 14 Aug 2013 13:35
  • By KushMechanic
  • joined 14 Aug'13 - 1 message
  • St James, Jamaica
Have you got free play on the pedals when in the neutral position. pedals should return to neutral then have 2-3mm free play to allow oil to return.
  • Posted 14 Aug 2013 18:22
  • By Leon_W
  • Tyne & Wear, United Kingdom
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
Olathe, KS, United States
Dallas/Ft Worth, United States
Terberg RT403
Hangcha CBD15
China
USD1,600
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
