Chyba MMI
Ahoj, potrebujem pomoc. Mám LINDE L14 AP, typ 1173, rok 2022. Vypína vozík, chyba T278, chyba MMI. Vymenil som MMI, kalibrácia OK, stále trvá chyba MMI 302, 310. Co treba skontrolovat? Dakujem za odpovede. S.
Please use English language...Littoral translation.
Hi, I need help. I have a LINDE L14 AP, type 1173, year 2022. Turns off the truck, T278 error, MMI error. I replaced the MMI, calibration OK, MMI error 302, 310 still persists. What should be checked? Thanks for the answers. S.
  • Posted 16 Feb 2025 23:15
  • By Savi
  • joined 16 Feb'25 - 3 messages
  • Slovakia
Ahoj, nastavil som znovu všetky parametre, skontroloval SW, verziu MMI, OK. kalibroval som poti akcelerátora, zdvihu. Vozík je funkcný. Stále obcas vypne a zobrazí chybu T278, pri diagnostike nájdem MMI 302, Add on1, Contains sub-group. Chybu 310 už nezobrazuje. Problém je, že chyba nie je trvalá.
S.
Hello again Savi...Please use English Language.....
Hi, I reset all parameters, checked SW, MMI version, OK. I calibrated the accelerator pedal, lift. The cart is functional. It still turns off occasionally and displays error T278, during diagnostics I find MMI 302, Add on1, Contains sub-group. It no longer displays error 310. The problem is that the error is not permanent.
  • Posted 25 Feb 2025 07:19
  • Modified 25 Feb 2025 11:38 by administrator
  • By Savi
  • Slovakia
302 Redundant sensor error #3
MMI 302
Description
Bit 0: Traction sensor 1 signal overflow (FENWICK: ?, 200msec)
Bit 1: Traction sensor 1 signal underflow (FENWICK: ?, 200msec)
Bit 2: Lifting/lowering sensor 1 signal overflow (FENWICK: ?, 200msec)
Bit 3: Lifting/lowering sensor 1 signal underflow (FENWICK: ?, 200msec)
Conditions of occurrence
Result
Possible causes
Steps to eliminate the fault
Error code combination with possible causes
310 Magnet missing
MMI 310
Description
Bit 0: Belly1 magnet missing
Bit 1: Turtle1 magnet missing
Bit 2: Horn magnet missing
Bit 5: Lp magnet missing
Bit 6: Traction magnet missing
  • Posted 23 Feb 2025 23:14
  • By michel_v
  • joined 8 Mar'08 - 1,039 messages
  • noord holland, Netherlands
edition #1291 - 23 July 2026
In the latest Forkliftaction News , it is a week of product launches and humanoids. Chinese equipment manufacturer Heli launches its new heavy-duty G3 Series 12T-18T capacity forklifts on to the global market while Clark launches two new lithium-ion powered forklifts to the North American market... Continue reading
Terberg RT223
Terberg YT223
Joachim (Joe) Heel Joachim (Joe) Heel
Chief executive officer, Peak Technologies
Head of UK & Ireland, ROYPOW Global
Senior global sales manager, Lift-Tek
Senior manager sustainability, KION Group
