« Check motor cover »
Hi!
I have a crown wave 60 that start beeping and says « check motor cover » when lowering and we can't move anymore or can't go down. I have to restart the wave and mess with the up/down keys and finally its good. How to fix this? I heard to just remove the cover plate under the platform and to clean there?
  • Posted 13 Mar 2024 00:44
  • By Djaztek
  • joined 23 Jan'24 - 84 messages
  • Quebec, Canada
Ok thanks I will try to check this out. It act like if someone or something would press the motor cover plate under the platform but there is nothing. So probably the switches
  • Posted 13 Mar 2024 01:00
  • By Djaztek
  • Quebec, Canada
If you lift up the platform using the ground controls, there is a cover that covers the drive motors under the operator platform. If this cover is depressed it will give off this alarm as it thinks there is an object under the operator platform. One of the switches may be bad or there could be something on this cover setting it off.
You can take off the cover and you will see the metal support bars that move and activate the switch.
  • Posted 13 Mar 2024 00:49
  • By DyslexicNerd_01
  • Wisconsin, United States
Mitsubishi FD200
UN Forklift FBR25NQC3
REPOWERTEK Inc
Sue Tomic Sue Tomic
Mitsubishi FD200
Mitsubishi FD200
