Check Engine Light On
Toyota 7FGCSU20-72857
I have a check engine light on (outline of an engine) and am wondering how to check or pull codes to further diagnose the light. The forklift runs great by the way. There is a small diagnosis port behind the battery that has 23 ports on it, but only the FP, E1, +B, VF2, WA and WB ports have terminals in them. Is there a way to short two of the terminals and get a blink code from the engine light?
I have already changed the O2 sensor and am planning on doing a tune-up (plugs, wires and cap). Any info you could share would go a long way, considering I have only a parts list for this forklift.
Thanks in advance.
  • Posted 12 Dec 2014 06:16
  • By 460beast
  • joined 12 Dec'14 - 6 messages
  • Utah, United States
For anyone who cares...check engine light (engine outlined light) is related to engine emissions. My issue was related to the LP regulator filter being clogged. Replaced the filter and retested. Light turned off as soon as the engine started.
  • Posted 13 Dec 2014 09:37
  • By 460beast
Its is definitely a hard fault. Light immediately came back on once I reconnected the battery. Double checked all fuses. May have to start tracing wires next.
  • Posted 12 Dec 2014 09:53
  • By 460beast
Thanks for the update feebs. I did find the "orange" plug. It is a single wire plug, but it only works with the SAS system. Disconnecting the battery was going to be my next step. Cross your fingers and hope it is just a ghost code.
  • Posted 12 Dec 2014 08:50
  • By 460beast
usually the diagnosis plug by the battery is for the analyser (prob spelt that wrong) and you can short two of the pins out to clear the error code and remove the management light if I remember, you can also just disconnect the battery for 20 seconds to do this. ive found with Toyotas that generally theres two type of codes, one which I call a spike code, which is like a flash error that the ecu/truck has detected but managed to correct itself and therefore truck runs fine but the mil light stays lit, and then theres an active code where the truck has a genuine error and the ecu/truck cant correct itself and the mil light stays lit and the truck runs faulty. easiest way is disconnect battery for 20secs or more then reconnect, start truck up and see if mil light comes back on, if the mil light doesn't come on straight away then run the truck around, full throttle and under load etc to see if comes on, if doesn't then its just a spike code, if it does, note when it appears i.e full throttle etc and at least you have a starting area to look at.
  • Posted 12 Dec 2014 08:46
  • By feebs
  • joined 17 Nov'14 - 50 messages
  • Yorkshire, United Kingdom
Ill see if i can't find that orange plug, ill keep you updated.
  • Posted 12 Dec 2014 08:37
  • By 460beast
check emails beasty. if it talks about unplugging the "matching" plug to do the self diagnosis bit, I think if memory still alive, it will be the orange plug located under the foot plate on the left side wiring loom.
let me know how you go.
  • Posted 12 Dec 2014 08:28
  • By feebs
feebs,
My email is shop54 at admiralbeverage dot com
The forklift is a 2006.
The engine is a:
2.237L Displacement
LP fuel
Engine family (EPA) number is: 6TIEB02.204Y
Engine family (CARB) number is: 6TIEB02.2L4Y
  • Posted 12 Dec 2014 08:10
  • By 460beast
Hi Pal,
email me with your contact details and I may have some info that could help you out.
  • Posted 12 Dec 2014 07:10
  • By feebs
Maxlion FD50T
Terberg RT403
