CAT NRR40 Intermittent reach
Working on a CAT NRR40 that will intermittently not reach. It will reach more often at low heights, once it does, the reach works until you stop using the command and try it again. The truck is not , eaking and hydraulic oil is full. Everything else on the truck functions correctly.
  • Posted 31 Mar 2016 00:45
  • By Lifttruckwrench
  • joined 29 Dec'15 - 24 messages
  • Tennessee, United States
Did you smell that funny noise?
Thanks stam, I'll try that
  • Posted 31 Mar 2016 22:22
typically an open in the overmast cable.
the reach solenoid is right infront of the cluster on top of the carriage under a plate with 2 bolts holding it down. some techs use 18/8 overmast cable. if so there is 2 extra wires in the cable you can substitute the reach solenoid wire for the time being to prove its the cable.
  • Posted 31 Mar 2016 09:38
  • By stam
SMV (Konecranes) 33-1200C
JLG G12-55A
JLG G12-55A
Libiao Robotics
