CAT. NR4500P-36 (AC) S/N; 8NR TRAC. INVERTER
doing a visual check, i found that inverter is severly heatead at one stud terminal (output phase U) of the inverter and causing an alarm 14, vissualy it is damaged. 8 (line cont. is ok). my question is: If i have to change the inverter, can i do it without having to do reprogramming, learninng. etc. have done it this way in other trucksn not this particular one.
Appreciate any advice to do it the right way.
  • Posted 1 Feb 2011 03:59
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
The controller is not Zapi. Be sure to order the correct controller (part number on original controller). The control cards on the pump amd traction inverters are not interchangable. If the power cable shows signs of overheating, you should replace it too. Get yourself a new controller. No programming needed.
  • Posted 9 Feb 2011 13:02
  • By CM_72
  • joined 6 Feb'11 - 3 messages
Ohhh.. sorry, maybe im wrong. the inverter i have is p/n: RL487777. how can i Know if it is a Zapi controller or not, i took the cover apart and inside cards says mitsubishi, on cover it only have part numbers. from the S/N you can see Chassis MFG.year (2008). SN is 8NR3821912
  • Posted 9 Feb 2011 07:42
  • Modified 9 Feb 2011 07:47 by poster
  • By roldann
thanks for your input CM_72, controller is not Zapi, and Truck is 2008 according to Serial Number. -valuable comment-
  • Posted 9 Feb 2011 05:32
  • By roldann
CM_72, thanks for the clarification
  • Posted 7 Feb 2011 00:14
If this truck has a ZAPI control system (i.e mgr year older than 2008), you will need to program the controller, but if it is 2008 and newer, simply install the component.
  • Posted 6 Feb 2011 05:45
  • By CM_72
yeah, you´re right. I was assuming the dealer to have a record of accessories and adjusments for that particular truck at the time it was deliveried, but somebody could have "tailored"it to it´s own requirements.
i will post later if have more questions.(need to better understand the manual)
Thanks for your comments.
  • Posted 2 Feb 2011 04:03
  • By roldann
the dealer will not know the weight of the carriage and attachments, nor the direction of the steering, nor what accessories (height encoder?, which direction the travel alarm is set for,)
  • Posted 1 Feb 2011 21:23
thyanks for you replay. Eduard.
Even being ordered from a dealer supplying Model and Serial number?
Can i do it if know the master paswsword
  • Posted 1 Feb 2011 09:25
  • By roldann
you will need to (re)program the controller
  • Posted 1 Feb 2011 08:36
Maxlion R2D35
Airman ENCL045
Maxlion R2D35
Airman ENCL045
