CAT EP20KT CODE 18 H-BRIDGE FIELD DRIVER FAULT
??? HOW DO I TEST THIS BEFORE REPLACING SUCH AN EXPENSIVE CARD???
  • Posted 17 Apr 2014 09:07
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Hi there! I javelin tried all of these steps and am unable to locate the issue. Multiple replacements of all 3 boards, motor swaps, harness swaps, leads multimetered. No luck. Any help?
  • Posted 19 Feb 2022 08:02
  • By DELTAa4
  • joined 19 Feb'22 - 1 message
  • Michigan, United States
You need to check the resistance of the motor field, should be approximately 0.7 ohms or failing to disassemble the engine and check the resistance of each field, you'll have to cut them, the resistance should be aprox 2.2 ohms, to my I cause me many problems when from the beginning was the motor.
  • Posted 3 Nov 2014 09:46
  • By RGAMEZO
  • joined 3 Nov'14 - 5 messages
  • Jalisco, Mexico
code 18 - Right motor, faulty field drive
Possible causes:
- faulty right motor field circuit
- faulty H Bridge board
- faulty logic card
- faulty controller harness
This code is triggered when the logic detects over current for right FET
Checks
- disconnect battery plug
- check right motor field cable terminals, logic card CN2-13 terminal and H-Bridge board CN2-16 terminal for abnormality.
If unacceptable: correct or replace cables
If acceptable:
check continuity between following terminals - right motor field cables, and also check logic card CN2-13 and CN2-63 (Neg)
If shorted: correct or replace faulty circuit
If not shorted:
turn on key and confirm code 18 is displayed
confirm voltage between CN2-13 and CN2-63 (Neg) with multimeter
If about 15v replace logic card
if about 0v replace H-Bridge board.
hope this helps
  • Posted 12 May 2014 05:18
SMV (Konecranes) 4632CC5
Komatsu FD25T17
