C5000 dash lights ALL flashing
truck was overheat. did an engine job.
E33 will not go away. and ALL lights keep flashing which is very annoying.
how to clear code and fix the lights flashing?
  • Posted 10 Jun 2014 10:16
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
echo3618@hotmail.com
Even the cheap one will erase codes and turn off the check engine light.
  • Posted 16 Jun 2014 20:39
The handset/ obd2 will show "no codes" if the code isn't an active code.
  • Posted 16 Jun 2014 12:17
  • By RCAV8TOR
  • Alabama, United States
I bought the one that on sale now at Prin.... Au.. $34.99 a vey simple one that read and erase codes. Don't think need a more expensive one with all the whistles and bells for forklifts anyways.
But since code on my truck is already gone after unplugging battery, cant be 100 % it will clear the code. It did read "no code" when I plugged it to the truck though.
  • Posted 14 Jun 2014 07:24
  • By hellokitty
Out of curiosity what is the make and model of the OBD2 Scanner. we are looking to purchase one???
  • Posted 14 Jun 2014 06:24
  • By Prentice
everything cleared after unplug battery overnight the 2nd time.
also bought an OBD2, seem would work on the truck too, good to keep for the future.
  • Posted 12 Jun 2014 04:44
  • By hellokitty
oh yeah jeremy has a good idea
if you look under the cup holder area you'll find a large plug that you can hook up an OBD2 scanner to.
I just didn't think of that being an ex cat tech, we had the diagnozer program which uses thier own designated plug and since i was always looking for that plug the OBD plug never occured to me.
  • Posted 11 Jun 2014 14:04
do you have an automotive scanner to clear code? If so you can look at temp sensor under live data, check it cold should be close to ambient temp.
  • Posted 11 Jun 2014 11:56
  • Modified 11 Jun 2014 11:57 by poster
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
like i said before if the pedal dance does not clear it then you will have to use the computer program. You will not get the lights to stop flashing till you clear the code, or resolve the outstanding issue that may still be present.
You can try replacing the temp sensor, it may be faulty but generally if a code is persistant the component that is failing is the cause or the ecm hardsets the code and the only way to clear it is the PC program.
try disconnecting the battery for 30 minutes and see if that clears it.
  • Posted 11 Jun 2014 09:11
  • Modified 11 Jun 2014 09:18 by poster
I had tried the pedal dance, no success. but even the code stays, that is fine.
what about the dash lights flashing, that's very annoying. any way to stop the flashing lights?
  • Posted 11 Jun 2014 01:22
  • By hellokitty
you can do a search here for 'pedal dance' and that will give you forum results for how to reset the system using the accerator pedal.
But keep in mind if this code is hard set you might need to gain computer access to reset it if pedal dance does not.
  • Posted 10 Jun 2014 22:35
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
