burst valve on hydraulic cylinders
Hi everyone,
I heard that there is a regulation\obligation that demands burst valve installation on lifting hydraulic cylinders.
My question is, if this requirement apply in forklift hydraulic cylinders?
If positive please note known source\standard.
Thank you all
  • Posted 21 May 2019 16:45
  • By gl_l
  • joined 9 Nov'09 - 18 messages
  • israel, Israel
FYI. In the days before ( early 1980's & prior) multiple lift cylinder mast designs the max rate of decent in the event of a lift line rupture was controlled by a thing called a flow regulator valve located a the base of the lifting cylinder.
  • Posted 26 May 2019 09:22
  • By johnr_j
Thank you Brewski,
Do you know if there is a directive in the above noted std. at the subject I have asked?
  • Posted 26 May 2019 04:14
  • By gl_l
  • israel, Israel
In the U.S.A., I believe, the standard used is in the ANSI standards for lift trucks. Not sure of the number. Found it. ANSI-B56.1
  • Posted 25 May 2019 02:21
  • Modified 25 May 2019 02:24 by poster
  • By BREWSKI
Yes, also called velocity fuse
  • Posted 24 May 2019 23:18
  • By gl_l
  • israel, Israel
Also known as velocity fuse?
  • Posted 24 May 2019 11:54
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
Crown CG33P5
Komatsu FD25T17
