bt op hse1000 order picker
Hi i have a problem with a bt 0p hse 1000 ser no 550095aa.
Code 7 is flashing on the controller, dead man not working brake so no drive, cab,forks & steering working battery charged but in poor condition. How do you check out dead man switches i have no manual for this order picker.No isle sensors fitted.
Thanks.
  • Posted 28 Jan 2016 05:20
  • By jan_d
  • joined 6 Dec'13 - 20 messages
  • United Kingdom
Showing items 1 - 15 of 15 results.
Why? The potentiometer is okay.
  • Posted 18 Jun 2021 03:26
  • Modified 18 Jun 2021 03:27 by poster
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
Hi try un plugging the connection on the steer motor potentiometer
  • Posted 18 Jun 2021 03:05
  • By richard_m
  • joined 11 Apr'13 - 112 messages
  • lancashire, United Kingdom
richardsforklifts @gmail.com
Hello,
I also have error 7 but the steering is working and the battery has 50 V (?!). Any suggestions?
Also, how to check errors on the A3?
Thanks!
  • Posted 18 Jun 2021 00:30
  • Modified 18 Jun 2021 00:30 by poster
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
ok i wll begin to test the cables. thanks a lot
  • Posted 6 Jan 2018 23:46
  • By robyroby
  • joined 11 Sep'17 - 7 messages
  • COMO, Italy
HI JUST TO LET YOU KNOW THE ERROR CODE 7 WAS DOWN TO THE BATTERY. FITTED NEW BATTERY ALL OK NOW.
THANKS.
  • Posted 6 Jan 2018 06:32
  • By jan_d
  • United Kingdom
  • Posted 6 Jan 2018 06:19
  • Modified 8 Jan 2018 06:41 by poster
  • By richard_m
a tecnicians tell me few weeks ago that can be the orange baecon light. I try to disconnect it but the error is also present.
thanks
  • Posted 5 Jan 2018 21:20
  • By robyroby
  • COMO, Italy
I M READING FROM LABEL
BT OPAL OM
MATR 291332
NO 291332AA/1996
  • Posted 5 Jan 2018 21:06
  • By robyroby
  • COMO, Italy
Have you got the correct model ?
  • Posted 4 Jan 2018 21:04
  • By richard_m
during the lift up or lift down few times display error C 025 and also few times rarely error C 125.
more and more often lately appears even if the forklift is not still running but i switched on error c016
SomeOne can tell me what i this errors.Thanks Robert
  • Posted 4 Jan 2018 20:19
  • By robyroby
  • COMO, Italy
Hi done a sg check on the battery and found 3 cells dead and at 0v and 1.5 so it looks like the battery is worn out getting another BT next week so i will try it, but i think the battery has had it's day.
  • Posted 3 Feb 2016 21:17
  • By jan_d
  • United Kingdom
Is there's another truck on site plug that battery in, Check the A3 error first
The pot should not be to stiff but you need a good battery for this error
  • Posted 2 Feb 2016 08:35
  • By richard_m
Ok thanks for the info i will check it out,the battery is in a poor state
1 cell shorted out and it is out of the truck,But would this stop the dead man working.
The pot on the steering gear chain is stiff is this normal?
  • Posted 2 Feb 2016 06:44
  • By jan_d
  • United Kingdom
error 7 the steering servo A3 is giving an error signal
see error code on A3.
I had the same fault before and it was down to a flat/bad battery
  • Posted 31 Jan 2016 08:37
  • Modified 1 Feb 2016 04:32 by poster
  • By richard_m
Hi has no one seen this model before? it has 2 dead man handle system you have to hold to take the magnetic brake off and then you get drive. The dead man must be some sort of proxy switch.
Thanks for any help you can give.
  • Posted 31 Jan 2016 04:24
  • By jan_d
  • United Kingdom
Airman ENCL045
Aichi SR18A
Noblelift
