BT LWE180 error E104
I got the forklift without the controller. I mounted a second hand controller and now i am stuck with E101. Is it possible to get rid of the error?
Thank you in advance
  • Posted 2 Mar 2022 19:36
  • Modified 3 Mar 2022 21:13 by poster
  • By SVAP
  • joined 2 Mar'22 - 7 messages
  • Slovenia
Hello thank you for the answer i made a mistake the error is E101.
Travel regulator does not correspond with the type of truck
Sorry
  • Posted 3 Mar 2022 21:13
  • By SVAP
  • Slovenia
Code E104
Description Switch-transistor to brake is short-circuited
Possible error
cause
Error in the travel regulator, output. A1/3.
Incorrect value on parameter 22
Action Check cabling and contacts. Measure Ohms on
the magnet coil (Y1) for the brake.
Value 13-15 ohm.
Check parameter 22
  • Posted 3 Mar 2022 20:15
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
